Hello all, looking for what the difference between these two parts might be. Datasheet is the same.
Only thing I find different on this website is the -01 variant is ROHS compliant.
Any help will be appreciated. Thank you in advance.
Hello Rashy.
Welcome to the forum. When I check the data sheet, the case options for the 00 state no options. The 01 lists that it has reverse air. Right now both options are Rohs compliant. This information would be listed under the case option codes on the data sheet.
Thank you for the quick reply. It says customer option air. Does this mean the reverse air could be changed to normal flow?
Hello Rashy,
I am going to apologize about the delay on this. I am checking with the Product Specialist on this question. I will let you know when I hear something.
Hello Rashy,
I got the confirmation. If you order the part with the 00. It would be the normal airflow. The 01 would just be the reverse.
