Difference between NLV17SZ07DFT2G and NL17SZ07DFT2G
Hello. Is there a difference between NLV17SZ07DFT2G and NL17SZ07DFT2G? (with VS without “V”). Your site redirects me to the latter when I search for the former. From what I read in the data sheet, the only difference is that NLV17SZ07DFT2G is automotive grade. Can I use one for the other?
Thank you for your inquiry. You are correct both parts are the same. The manufacturer has the one sent through the qualification process; both will work the same.
