DigiKey Standard, Wire Stripper DKS-STRIPPER6MM2: Minimum Strip Length and Increment?
DigiKey Standard is DigiKey’s own line of products for electronics hobbyists and workers, offering tools and equipment everyone can use to prototype, make, and test their projects. One of the tools we have on tap is DKS-STRIPPER6MM2, an adjustable wire stripper/cutter. We’ve had some inquires recently on what the adjustment increment is for this stripper; is this fixed or known?
The strip increment for this product is 1mm per adjustment, with a 3mm minimum. You can check this out, as well as additional information on use of the tool, in an instructional YouTube short DigiKey has created.
