I have purchased a Hammond Manufacturing box from you pn: PJ20168RL (PJ20168RL-ND). I need the following dimension:
which is the vertical dimension between the pem nuts on the rear of the box.
Thanks! Charlie Allan
charlie.allan@rocklogic.com
Hi,
Welcome to the Digikey tech forum. I sent a request for this information and will post as soon as I get it.
Hi David,
That is the dimension for the inner panel. I need the one for the pem nuts on the back side of the box as I indicated on my mark-up drawing.
Charlie
Thank you for your follow up.
I downloaded the step file to this enclosure, looks like the spacing between the mounting holes for the steel feet is 470.814mm ( 18.536 inches )
My apologies, I thought those were the dimensions given from a different perspective.
