For iPad 11 3rd gen around the charging port.
Got a link for this little guy?
Hi theupel2,
I don’t have any inside info on this one. Google claims that the “DZ37A8” is just a board designator rather than a part number.
The symbol is that of a bi-directional TVS (transient voltage suppressor). The text below the “DZ” part seems to indicate either 27V stand-off voltage, 27V minimum breakdown voltage, or possibly 27V maximum clamping voltage. The first is the most likely, but no way to know for sure.
If you knew what voltage was normally present at pin 2, that would help to narrow that down. If it were the stand-off voltage, then I would expect voltage at pin 2 to be normally as high as around 24V. If it’s always much lower than that, then the 27V could be one of the other mentioned specs.
Obviously, 100pF and 4A rating are self-explanatary, and “0402” implies an 0402-sized package.
Here are some parts in that general range, though none meet all of those specs:
