Can you suggest a direct replacement for a TDA2050 amplifier. It is used in a Marshall amp’s output stage.
Welcome to the community. A possible option is the NTE Electronics NTE7169. Unfortunately, this part is not in our system. Please check the NTE site to see where you can purchase.
Below are some similar options to consider, please review datasheet specifications before ordering:
Click here for 296-43523-5-ND | 296-36099-5-ND
Below are some similar RoHS compliant options to consider (not recommended unless you strictly need RoHS as these have 90 degree bent leads and may be harder to solder):
Click here for 296-43520-5-ND | 296-43521-5-ND
Original NTE Datasheet for comparison reference:
https://www.st.com/resource/en/datasheet/cd00000131.pdf
