------Question for MM5Z3V9T5G Please Put your question below------
Datasheet sheet shows this is a 2% tolerance part. But Digikey says it is 6.41%. Which is correct?
We have this part number from two manufacturers. onsemi’s website indicates it is +/- 5% tolerance.
I see! Thanks for your quick response!
Someone replied to your post.
| Kristof_2649 DigiKey Employee
March 2 |
Onsemi has confirmed it should be 5%, as Kristof found.
Thank you! The same PN made by Diodes is a 2% part. That is why I was confused.
Don
| Kaleb_Kohlhase DigiKey Employee
March 9 |
