I need assistance in choosing the correct led driver/circuit to power up a led backlight of a 7in 800x480 display.
I’m looking for a driver that can also accept a PWM signal from a teensy 3.2 to control brightness, will like to be able to dim the screen.
Here are the electrical specifications of the display.
A boost regulator or control IC compatible with 5v input such as the AP572x parts could work. There are similar parts in that product family available if a higher peak current capacity proves needful.
