DIY Solder Stencil Vacuum Table with Shop Vacuum
You stated that the STL files would be available here but I see no link to them. Where are the enclosure 3D print files stored?
Your youtube video mentioned your boards and your stencils but I got the impression that you have to print the inner frame for the pc board for each different size board you use. Also what size stencils do you use? Are they all the same size say 150mm x 150mm? Thank you.
Looking at the video, he did state he would have all the design files linked in Maker.IO.
It appeared the stencils seemed pretty universal, but placement would depend on each individual board/stencil combination.
Maybe someone that handles the information in Make.IO can add to this post.
Hello @Southerner and @David_1768 ,
We’ve reached out the Zach, The Byte Sized Engineer, to see if he can make the files avaiable. I’m not sure if they were mistakenly taken down or were never added.
As soon as we hear back, I’ll reach back out.
Thank you for bringing this to our attention. A link to the 3D model files has been added to the post.
