DKRed with no solder mask?
Is it possible to use the DKRed PCB service and omit the solder mask?
How would I do this. If I select “None” for solder mask it does not allow a DKRed quote. Perhaps I select the Red standard and then leave the solder mask layer blank?
Thanks
Greetings,
The validation logic probably doesn’t accommodate that case at present, but there’s nothing stopping you from providing a mask layer with a stop aperture covering the entire board…
Thank you Rick, I will do exactly that.
cheers
