Does SQ Series Cement-Housed High-Power Resistors need additional heat sink to use it upto rated power rating.
TE Connectivity’s documentation they list does not show that heatsinking would be needed.
Hi @gbrahmayya ,
Just keep in mind the derating curve per page 21/40 per datasheet.
- Exceeding these ratings or not providing enough free space around the resistor would likely require a heat sink and/or a fan.
Also be sure to be within the RCWV:
Thanks for suggestion.
Hello @Ryan_2724 ,
Thanks details explanation.
i am planning to use 27Ohm resistor PN “3-2176632-5”. which rated for 60W. its RCWV is ~40.
in my application, it’ll be used for 27W.
