------Question for TI.92.2113 Please Put your question below------
Does this antenna have the pin in the SMA or the socket?
Will it work with LoRa devices?
Hello igroves,
This is a male connection SMA(M) - the pin is associated with the antenna as shown here:
The antenna is designed for the 915 MHz ISM band which is defined in the antenna datasheet as 902 MHz to approximately 928 MHz.
LoRa is generally confined between 902 MHz to 928 MHz. Note that the 915 MHz is in the middle of the LoRa band. Consequently, this antenna is designed for the 915 (33-centimeter) band.
Best Wishes,
