Driver Specification Sheet Model No:: D27TG35-06 question?
I purchased a pair of Tympany Model No:: [D27TG35-06](Peerless by Tymphany) Tweeters from DigiKey.
The polarity on the terminals are not marked.
Which terminal is the positive?
thanks
Rocky
Hi @rockyysdt ,
At least in some cases the marking is embossed to the body.
Cheers, heke
Hi rockyysdt,
Welcome to the DigiKey TechForum community.
The polarity is given on the data sheet as per the mechanical drawing of the bottom view as in the snip below from that same data sheet: D27TG35-06 Product Sheet
And as heke said it is likely embossed on the part itself as well.
Hope that helps.
