I need the courtesy light for the passenger side of my E450 that is used as a chassis for my 2014 Jayco Greyhawk. Model # is 24004/24014 made by Judco. They referred me to you.
From my research it appears your vehicle uses the lamp size “T-3 1/4 wedge”. Below is a link to the 12v options we carry for you to verify if any will work for you:
Incandescent, Neon Lamps | Electronic Components Distributor DigiKey
My apologies. I need the entire fixture. Mine is broken and will no longer stay in place.
Thank you.
Hi hazkeg ,
It is recommended to contact Judco directly:
Automotive Division (248) 624-6840
judcosales@judco.net
