Emergency Stop Push Button with Protective Cover
Hello everyone,
I am looking for an emergency stop (E-stop) push button that includes a protective cover, guard, or flip-up safety cover to prevent accidental activation.
The intended application is aerospace or industrial equipment, so I am preferably looking for a robust, panel-mount, aerospace-grade or industrial-grade solution.
Could anyone recommend suitable products or manufacturers?
Thank you.
Hello widyaashari,
I have no search parameter for the features you list; you don’t give any voltage or amperage requirements. We have a part 450-2416049-7-ND Panel Mount, Front Push-Lock, Turn-Reset. I have the manufacturer link to the part on the right side they give chat and call contact information I recommend contacting them as I believe your list will not be a package part.
Link PBES22L017R : ALCOSWITCH Emergency Stop Switches: 22mm Mounting Hole, Pushbutton | TE Connectivity
Hello @widyaashari,
You may be interested in guards such as this:
The challenge is to match the guard to the desired switch E-Stop switch.
Recommend you start by exploring the Schneider catalog.
Like nearly all industrial control switches, you will need to consider things from a family of parts perspective. In this case, we are exploring the Harmony XB4 switches.
Sincerely,
You may also want to consider part 84-906: 84-906 EAO | Accessories | DigiKey
This shroud will work with any EAO E-stop part number that begins with 84-5 or 84-6: Emergency Stop (E-Stop) Switches | Safety Products | DigiKey
Hope this helps.
