EMMC Flashing Error
Hi Robert,
When emmc is flashed with dd firmware.img from SD card, it shows errors:
Blockquote
debian@beaglebone:~/ncu$ [ 206.968662] EXT4-fs error (device mmcblk1p1): ext4_v
alidate_block_bitmap:376: comm cp: bg 33: bad block bitmap checksum
[ 206.981770] EXT4-fs error (device mmcblk1p1): ext4_validate_block_bitmap:376:
comm cp: bg 34: bad block bitmap checksum
[ 206.997011] EXT4-fs error (device mmcblk1p1): ext4_validate_block_bitmap:376:
comm cp: bg 35: bad block bitmap checksum
[ 207.010204] EXT4-fs error (device mmcblk1p1): ext4_validate_block_bitmap:376:
comm cp: bg 36: bad block bitmap checksum
Blockquote
But It is ok flashed with BalenaEtcher program through micro usb.
Any suggestions?
Thank you,
David Zhou
Besides running fsck, i don’t know… I’ve never really used the dd *.img in a production environment, i prefer to use rsync and friends to create and copy the file system to the target drive…
Regards,
Hi Robert,
emmc_error_fsck.txt (65.1 KB)
I uploaded output from fsck command. Please take a look for me. Appreciate your help.
Best Regards,
David Zhou
Hi Robert,
I figured out, it was the image creation went wrong. For some reason,
rootfs: 111499/951552 files (0.1% non-contiguous), 895192/3846144 blocks
895192 blocks are not enough.
Not sure why.
Best Regards,
David
