Epcos - TDK has made available the part markings for the B3292_C/D - X2 Standard capacitors.
If the capacitor is wide enough, the entire marking will be on the top. In this case, the stamping
will contain the following information:
1st line: Manufacturer’s logo, lot number, revision status
2nd line: Date code, capacitance, cap. tolerance, rated voltage
3rd line: Type number, interference suppression, sub class, style/self-healing
4th line: Climatic category
5th line: Marks of conformity
If the capacitor is not wide enough for the entire marking, the information in the marking will be
split between the top and side. In this case, the following partial information will be found on the
top:
Applicable Part Numbers
| Digi-Key Part Number | Manufacturer Part Number |
| 495-B32922C3473K189TR-ND,495-B32922C3473K189CT-ND | B32922C3473K189 |
| 495-B32924C3155M189TR-ND,495-B32924C3155M189CT-ND | B32924C3155M189 |
| 495-B32923C3105M289CT-ND,495-B32923C3105M289TB-ND | B32923C3105M289 |
| 495-B32923C3684M289CT-ND,495-B32923C3684M289TB-ND | B32923C3684M289 |
| 495-B32921C3333K289CT-ND,495-B32921C3333K289TB-ND | B32921C3333K289 |
| 495-6920-ND | B32923D3334K000 |
| 495-4803-ND | B32921C3683K000 |
| 495-1893-ND | B32926C3335M000 |
| 495-1894-ND | B32926C3475M000 |
| 495-76808-ND | B32922C3333K000 |
| B32921C3333K000-ND | B32921C3333K000 |
| 495-4938-2-ND,495-4938-1-ND | B32923C3155M189 |
| 495-4783-ND | B32926C3225K000 |
| 495-1890-ND | B32924C3565M000 |
| 495-76821-ND | B32923C3684K000 |
| 495-1885-ND | B32923C3225M000 |
| 495-2318-ND | B32921C3104M000 |
| 495-4779-ND | B32922C3473K000 |
| 495-1896-ND | B32926C3685M000 |
| 495-4793-ND | B32926C3685K000 |
| 495-2321-ND | B32922C3334M000 |
| 495-6907-ND | B32922C3224K000 |
| 495-4794-ND | B32926C3106K000 |
| 495-75594-ND | B32922C3154K000 |
| 495-2320-ND | B32922C3224M000 |
| 495-6910-ND | B32922C3474K000 |
| 495-4207-ND | B32923C3474M000 |
| 495-1887-ND | B32924C3225M000 |
| 495-4204-ND | B32923C3224M000 |
| 495-1888-ND | B32924C3335M000 |
| 495-1895-ND | B32926C3565M000 |
| 495-6904-ND | B32921C3473M000 |
| 495-1891-ND | B32926C3106M000 |
| 495-4121-ND | B32921C3333M000 |
| 495-6913-ND | B32922C3684K000 |
| 495-1884-ND | B32923C3155M000 |
| 495-1892-ND | B32926C3225M000 |
| 495-2322-ND | B32922C3474M000 |
| 495-6908-ND | B32922C3473M000 |
| 495-4935-2-ND,495-4935-1-ND | B32922C3333K189 |
| 495-4946-2-ND,495-4946-1-ND | B32921C3333M189 |
| 495-4897-1-ND,495-4897-3-ND | B32922C3224K289 |
| 495-6909-2-ND,495-6909-1-ND | B32922C3474K189 |
| 495-4869-1-ND,495-4869-3-ND | B32921C3333M289 |
| 495-4205-ND | B32923C3334M000 |
| 495-76822-ND | B32923C3824M000 |
| 495-4425-ND | B32922C3154M000 |
| 495-6448-ND | B32926C3156M000 |
| 495-6455-ND | B32928C3306M000 |
| 495-6454-ND | B32928C3256K000 |
| 495-6905-2-ND,495-6905-1-ND | B32922C3104K189 |
| 495-4867-1-ND,495-4867-3-ND | B32921C3103M289 |
| 495-76548-1-ND,495-76548-2-ND | B32923C3334M289 |
| 495-76977-1-ND,495-76977-3-ND | B32922C3474K289 |
| 495-4871-1-ND,495-4871-3-ND | B32921C3103K289 |
| 495-6906-2-ND,495-6906-1-ND | B32922C3224K189 |
| 495-76605-2-ND,495-76605-1-ND | B32922C3684K189 |
| 495-6451-ND | B32928C3206M000 |
| 495-4208-ND | B32923C3684M000 |
| 495-4843-1-ND,495-4843-3-ND | B32922C3334K289 |
| 495-4958-2-ND,495-4958-1-ND | B32922C3473M189 |
| 495-6453-ND | B32928C3256M000 |
| 495-76547-1-ND,495-76547-2-ND | B32922D3334K289 |
| 495-4936-2-ND,495-4936-1-ND | B32924C3105K189 |
| 495-4210-ND | B32924C3105M000 |
| 495-4198-2-ND | B32922C3104M189 |
| 495-2323-ND | B32922C3684M000 |
| 495-6902-1-ND,495-6902-3-ND | B32921C3473K289 |
| 495-5052-2-ND,495-5052-1-ND | B32922C3334M189 |
| 495-76847-ND | B32924C3275K000 |
| 495-4200-2-ND,495-4200-1-ND | B32922C3224M189 |
| 495-76633-1-ND,495-76633-3-ND | B32923C3474M289 |
| 495-4893-1-ND,495-4893-3-ND | B32922C3333K289 |
| 495-76971-1-ND,495-76971-3-ND | B32922C3154M289 |
| 495-4952-2-ND,495-4952-1-ND | B32921C3103M189 |
| 495-4427-3-ND | B32921C3104M289 |
| 495-6914-2-ND,495-6914-1-ND | B32922C3684M189 |
| 495-6450-ND | B32926D3156K000 |
| 495-4934-2-ND,495-4934-1-ND | B32922C3154K189 |
| 495-76980-1-ND,495-76980-3-ND | B32923C3105K289 |
| 495-6919-2-ND,495-6919-1-ND | B32923C3105M189 |
| 495-4911-1-ND,495-4911-3-ND | B32922C3104K289 |
| 495-4863-1-ND,495-4863-3-ND | B32921C3683M289 |
| 495-4197-2-ND | B32921C3104M189 |
| 495-2324-ND | B32923C3105M000 |
| 495-4940-2-ND,495-4940-1-ND | B32921C3683M189 |
| 495-4476-ND | B32922C3104K000 |
| 495-4202-1-ND,495-4202-3-ND | B32922C3334M289 |
| 495-2316-ND | B32921C3103M000 |
| 495-6917-2-ND,495-6917-1-ND | B32923C3105K189 |
| 495-4964-2-ND,495-4964-1-ND | B32922C3154M189 |
| 495-4371-3-ND | B32922C3224M289 |
| 495-76979-1-ND,495-76979-3-ND | B32923C3684K289 |
| 495-75765-ND | B32922C3223M000 |
| 495-4957-2-ND,495-4957-1-ND | B32922C3223M189 |
| 495-4203-ND | B32923C3154M000 |
| 495-B32921C3223M189TR-ND,495-B32921C3223M189CT-ND,495-B32921C3223M189DKR-ND | B32921C3223M189 |
| 495-B32923D3334K289CT-ND,495-B32923D3334K289TB-ND | B32923D3334K289 |
| 495-B32923C3474K289CT-ND,495-B32923C3474K289TB-ND | B32923C3474K289 |
| 495-B32923C3224M189TR-ND,495-B32923C3224M189CT-ND | B32923C3224M189 |
| 495-6918-ND | B32923C3105K000 |
| 495-B32922C3683K289CT-ND,495-B32922C3683K289TB-ND | B32922C3683K289 |
| 495-75766-ND | B32922C3683M000 |
| 495-B32926C3335K000-ND | B32926C3335K000 |
| B32921C3223K000-ND | B32921C3223K000 |
| 495-77154-ND | B32923C3225K000 |
| B32924C3565K000-ND | B32924C3565K000 |
| 495-6923-ND | B32924D3335M000 |
| 495-6922-ND | B32924D3335K000 |
| 495-6915-ND | B32922D3334K000 |
| 495-75768-ND | B32926C3825M000 |
| 495-4787-ND | B32924C3225K000 |
| 495-5051-ND | B32922C3334K000 |
| 495-7397-ND | B32924D3475K000 |
| 495-6903-ND | B32921C3473K000 |
| 495-2319-ND | B32922C3104M000 |
| 495-4804-ND | B32926C3475K000 |
| 495-6916-ND | B32922D3334M000 |
| 495-1889-ND | B32924C3475M000 |
| 495-4840-ND | B32921C3103K000 |
| 495-4963-2-ND,495-4963-1-ND | B32924C3105M189 |
| 495-1886-ND | B32924C3155K000 |
| 495-6912-ND | B32922C3683K000 |
| 495-4909-1-ND,495-4909-3-ND | B32922C3474M289 |
| 495-77002-2-ND,495-77002-1-ND | B32922C3683K189 |
| 495-6911-2-ND,495-6911-1-ND | B32922C3474M189 |
| 495-75767-2-ND,495-75767-1-ND | B32923C3224K189 |
| 495-B32923C3824M289CT-ND,495-B32923C3824M289TB-ND | B32923C3824M289 |
| 495-76840-ND | B32922C3564K000 |
| 495-4206-ND | B32923C3474K000 |
| 495-4199-3-ND | B32922C3104M289 |
| 495-4944-2-ND,495-4944-1-ND | B32923C3684K189 |
| 495-4201-ND | B32922C3333M000 |
| 495-77005-2-ND,495-77005-1-ND | B32924C3155K189 |
| 495-4122-ND | B32921C3683M000 |
| 495-6921-2-ND,495-6921-1-ND | B32924C3225M189 |
| 495-77003-2-ND,495-77003-1-ND | B32921C3683K189 |
| 495-4209-ND | B32924C3105K000 |
| 495-2317-ND | B32921C3223M000 |
| 495-6449-ND | B32926D3156M000 |
| 495-76806-ND | B32922C3103M000 |
| 495-4925-1-ND,495-4925-3-ND | B32921C3473M289 |
| 495-4213-ND | B32924C3684M000 |
| 495-4954-2-ND,495-4954-1-ND | B32921C3473M189 |
| 495-4211-ND | B32924C3155M000 |
| 495-4844-1-ND,495-4844-3-ND | B32921C3223M289 |
| 495-7094-2-ND,495-7094-1-ND | B32923C3474M189 |
| 495-5053-2-ND,495-5053-1-ND | B32922C3683M189 |
| 495-6452-ND | B32928C3206K000 |
| 495-4212-ND | B32924C3684K000 |
| 495-76640-2-ND,495-76640-1-ND | B32923C3474K189 |
| 495-76978-1-ND,495-76978-3-ND | B32922C3684M289 |
| B32923C3334K000-ND | B32923C3334K000 |
| B32923D3334M000-ND | B32923D3334M000 |
| B32923C3224K000-ND | B32923C3224K000 |
| B32923C3224K289-ND | B32923C3224K289 |
| B32922D3334K189-ND | B32922D3334K189 |
| 495-1897-ND | B32926C3825K000 |
| B32924D3475M000-ND | B32924D3475M000 |
| B32921C3103K189-ND | B32921C3103K189 |
| B32922C3154K289-ND | B32922C3154K289 |
| B32924C3684K189-ND | B32924C3684K189 |
| B32922D3334M289-ND | B32922D3334M289 |
| B32921C3223K289-ND | B32921C3223K289 |
| B32923D3334M289-ND | B32923D3334M289 |
| B32921C3333K189-ND | B32921C3333K189 |
| B32923C3155M289-ND | B32923C3155M289 |
| B32921C3683K289-ND | B32921C3683K289 |
| B32922C3103M189-ND | B32922C3103M189 |
| B32922C3274M000-ND | B32922C3274M000 |
| B32922C3823K189-ND | B32922C3823K189 |
| 495-B32926C3395M000-ND | B32926C3395M000 |
| B32922C3683M289-ND | B32922C3683M289 |
| B32924C3684M189-ND | B32924C3684M189 |
| B32922D3394M000-ND | B32922D3394M000 |
| B32921C3223K189-ND | B32921C3223K189 |
| B32923D3334M189-ND | B32923D3334M189 |
| B32921C3473K189-ND | B32921C3473K189 |
| B32923C3334M189-ND | B32923C3334M189 |
| B32923C3224M289-ND | B32923C3224M289 |
| B32922C3333M189-ND | B32922C3333M189 |
| B32923C3684M189-ND | B32923C3684M189 |
| B32922C3473M289-ND | B32922C3473M289 |
| B32922C3473K289-ND | B32922C3473K289 |
| B32922C3334K189-ND | B32922C3334K189 |
| B32923D3334K189-ND | B32923D3334K189 |
| B32924C3225K189-ND | B32924C3225K189 |
| B32922C3333M289-ND | B32922C3333M289 |
| B32922D3334M189-ND | B32922D3334M189 |
| B32922C3223K000-ND | B32922C3223K000 |
| B32924C3824M000-ND | B32924C3824M000 |
| B32924D3225K000-ND | B32924D3225K000 |
| B32921C3153M000-ND | B32921C3153M000 |
| B32923C3564K000-ND | B32923C3564K000 |
| B32923C3824K000-ND | B32923C3824K000 |
| B32924D3225M000-ND | B32924D3225M000 |
| B32923C3394K000-ND | B32923C3394K000 |
| B32922C3564M000-ND | B32922C3564M000 |
| B32923C3564M000-ND | B32923C3564M000 |
| B32923D3155K000-ND | B32923D3155K000 |
| B32923D3155M000-ND | B32923D3155M000 |
| B32924C3824K000-ND | B32924C3824K000 |
| B32926C3565K000-ND | B32926C3565K000 |
| B32923C3564M289-ND | B32923C3564M289 |
| B32922C3564M189-ND | B32922C3564M189 |
| B32923C3154K000-ND | B32923C3154K000 |
| B32924C3824K189-ND | B32924C3824K189 |
| B32923C3824M189-ND | B32923C3824M189 |
| B32923C3824K289-ND | B32923C3824K289 |
| B32923C3564M189-ND | B32923C3564M189 |
| B32922C3274K289-ND | B32922C3274K289 |
| B32923C3564K289-ND | B32923C3564K289 |
| B32922C3564K189-ND | B32922C3564K189 |
| B32924C3824M189-ND | B32924C3824M189 |
| B32921C3153M189-ND | B32921C3153M189 |
| B32922C3223K289-ND | B32922C3223K289 |
| 495-4865-1-ND,495-4865-3-ND | B32922C3223M289 |
