Epcos - TDK B3202_ - Y2 Standard EMI Suppression Capacitors
Epcos - TDK has made available the part markings for the B3202_ - Y2 Standard capacitors
If the capacitor is wide enough, the entire marking will be on the top. In this case, the stamping
will contain the following information:
1st line: Manufacturer’s logo, lot number, revision status
2nd line: Date code, capacitance, cap. tolerance, rated voltage
3rd line: Type number, interference suppression, sub class, style/self-healing
4th line: Climatic category
5th line: Marks of conformity
If the capacitor is not wide enough for the entire marking, the information in the marking will be
split between the top and side. In this case, the following partial information will be found on the
top:
Applicable Part Numbers
Digi-Key Part Number Manufacturer Part Number
495-B32021A3103M189TR-ND,495-B32021A3103M189CT-ND B32021A3103M189
495-B32021A3332M189TR-ND,495-B32021A3332M189CT-ND B32021A3332M189
495-3804-ND B32023A3334M000
495-3808-ND B32024A3334M000
495-3793-ND B32022A3153M000
495-3815-ND B32026A3474M000
495-4839-ND B32021A3472K000
495-3809-ND B32024A3474M000
495-3819-ND B32026A3105M000
495-3800-ND B32023A3683M000
495-4767-ND B32022A3333K000
495-5039-ND B32022A3103K000
495-3812-ND B32024A3824M000
495-4086-ND B32021A3102M000
495-3796-ND B32022A3473M000
495-4967-2-ND,495-4967-1-ND B32021A3222M189
495-3794-ND B32022A3223M000
495-7394-ND B32023B3104K000
495-4781-ND B32021A3102K000
495-3802-ND B32023A3154M000
495-4788-ND B32021A3222K000
495-4080-ND B32021A3332K000
495-4961-2-ND,495-4961-1-ND B32022A3223M189
495-5034-1-ND,495-5034-3-ND B32021A3103M289
495-4085-ND B32021A3822M000
495-4077-ND B32021A3103M000
495-76958-1-ND,495-76958-3-ND B32022A3473M289
495-4962-2-ND,495-4962-1-ND B32021A3102M189
495-4082-ND B32021A3472M000
495-4912-1-ND,495-4912-3-ND B32021A3152M289
495-4079-ND B32021A3222M000
495-5036-1-ND,495-5036-3-ND B32021A3332M289
495-4902-1-ND,495-4902-3-ND B32022B3223M289
495-4084-ND B32021A3682K000
495-4929-1-ND,495-4929-3-ND B32021A3682M289
495-4081-ND B32021A3332M000
495-5035-1-ND,495-5035-3-ND B32021A3222M289
495-B32021A3472K189TR-ND,495-B32021A3472K189CT-ND,495-B32021A3472K189DKR-ND B32021A3472K189
495-B32021A3222K189TR-ND,495-B32021A3222K189CT-ND B32021A3222K189
495-B32022A3103M189TR-ND,495-B32022A3103M189CT-ND B32022A3103M189
495-B32026A3334M000-ND B32026A3334M000
495-B32023A3394M000-ND B32023A3394M000
495-B32022A3153K000-ND B32022A3153K000
495-B32021A3102K289CT-ND,495-B32021A3102K289TB-ND B32021A3102K289
495-3810-ND B32024A3564M000
495-B32023A3823M000-ND B32023A3823M000
495-3792-ND B32022A3103M000
495-3803-ND B32023A3224M000
495-3806-ND B32024A3154M000
495-3801-ND B32023A3104M000
495-5032-ND B32024C3474M000
495-5038-ND B32021A3682M000
495-3795-ND B32022A3333M000
495-3807-ND B32024A3224M000
495-4790-ND B32022B3223M000
495-3797-ND B32022A3683M000
495-3798-ND B32022A3823M000
495-4769-ND B32022B3473M000
495-3813-ND B32024A3105M000
495-3799-ND B32023A3473M000
495-7393-ND B32022B3473K000
495-B32022A3473M003-ND B32022A3473M003
495-4773-ND B32022B3223K000
495-3811-ND B32024A3684M000
495-4916-1-ND,495-4916-3-ND B32022A3103M289
495-77178-1-ND,495-77178-3-ND B32021A3472M289
495-4083-ND B32021A3562M000
495-76543-2-ND,495-76543-1-ND B32023A3104M189
495-7399-ND B32024B3684K000
495-4078-ND B32021A3152M000
495-77040-2-ND,495-77040-1-ND B32023A3154M189
495-5033-1-ND,495-5033-3-ND B32021A3102M289
495-7398-ND B32024B3474K000
495-5037-2-ND,495-5037-1-ND B32021A3472M189
495-4923-1-ND,495-4923-3-ND B32021A3472K289
B32023A3334K000-ND B32023A3334K000
B32022A3563K000-ND B32022A3563K000
495-3818-ND B32026A3824M000
495-3817-ND B32026A3684M000
B32021A3822K000-ND B32021A3822K000
B32023B3154K000-ND B32023B3154K000
495-3816-ND B32026A3564M000
B32024B3334M000-ND B32024B3334M000
B32024B3684M000-ND B32024B3684M000
B32026B3564M000-ND B32026B3564M000
B32026B3105K000-ND B32026B3105K000
B32021A3562K000-ND B32021A3562K000
B32024B3224M000-ND B32024B3224M000
B32024B3474M000-ND B32024B3474M000
B32023B3104M000-ND B32023B3104M000
B32026A3474K000-ND B32026A3474K000
B32021A3152K000-ND B32021A3152K000
B32023B3154M000-ND B32023B3154M000
B32023A3563M000-ND B32023A3563M000
B32024C3684M000-ND B32024C3684M000
B32023B3683M000-ND B32023B3683M000
B32026B3824M000-ND B32026B3824M000
B32021A3122M000-ND B32021A3122M000
495-B32024C3684K000-ND B32024C3684K000
B32022A3223M289-ND B32022A3223M289
B32026A3684K000-ND B32026A3684K000
B32022A3683M189-ND B32022A3683M189
B32024C3474K000-ND B32024C3474K000
B32021A3122K000-ND B32021A3122K000
B32021A3182K000-ND B32021A3182K000
B32023B3104K189-ND B32023B3104K189
B32021A3252M000-ND B32021A3252M000
B32021B3392M000-ND B32021B3392M000
B32021B3392K000-ND B32021B3392K000
B32023B3683M189-ND B32023B3683M189
B32022A3103K189-ND B32022A3103K189
B32022A3823M189-ND B32022A3823M189
B32022B3473M189-ND B32022B3473M189
B32023A3823K000-ND B32023A3823K000
B32022A3563M000-ND B32022A3563M000
B32023B3224M000-ND B32023B3224M000
B32021A3252K000-ND B32021A3252K000
B32023A3473K000-ND B32023A3473K000
B32023B3224K000-ND B32023B3224K000
B32021A3392M000-ND B32021A3392M000
B32021A3272K000-ND B32021A3272K000
B32022A3333M189-ND B32022A3333M189
B32022A3153M189-ND B32022A3153M189
B32023A3473M189-ND B32023A3473M189
B32021A3622M000-ND B32021A3622M000
B32022B3473K289-ND B32022B3473K289
B32023A3683K189-ND B32023A3683K189
B32024B3224K000-ND B32024B3224K000
B32021A3682M189-ND B32021A3682M189
B32023A3473M289-ND B32023A3473M289
B32021A3332K289-ND B32021A3332K289
B32022B3223K289-ND B32022B3223K289
B32022A3333M289-ND B32022A3333M289
B32022A3683M289-ND B32022A3683M289
B32021A3182M000-ND B32021A3182M000
B32023B3104M289-ND B32023B3104M289
B32024B3334K000-ND B32024B3334K000
B32021A3152M189-ND B32021A3152M189
B32021A3102K189-ND B32021A3102K189
B32023A3563M289-ND B32023A3563M289
B32024B3224K189-ND B32024B3224K189
B32021A3622K000-ND B32021A3622K000
B32022A3153M289-ND B32022A3153M289
B32026B3105M000-ND B32026B3105M000
B32021A3682K289-ND B32021A3682K289
B32022A3273K000-ND B32022A3273K000
B32021A3272M000-ND B32021A3272M000
B32022A3393K000-ND B32022A3393K000
B32021A3222K289-ND B32021A3222K289
B32021A3562K289-ND B32021A3562K289
B32022A3473M189-ND B32022A3473M189
B32023A3104M289-ND B32023A3104M289
B32022B3223M189-ND B32022B3223M189
B32022A3393M000-ND B32022A3393M000
B32026B3824K000-ND B32026B3824K000
B32023B3104M189-ND B32023B3104M189
