We get a few common questions from customers concerning the PowerHap Actuator from EPCOS (TDK). Below are answers we’ve received from TDK.
Mounting Recommendation:
Using double sided tape is recommended for holding the PowerHap in place. The screw holes on the body, such as Z63000Z2910Z1Z38, can be used but if you tighten to deep then can actually touch the piezo element, hindering movement. -
Which driver is being used to actuate the piezos?
We recommend using piezo specific drivers such as one of the TDK eval boards also available at Digi-Key. The actual voltage that the part sees can vary if not driven properly. Actual voltage affects the displacement, force and acceleration.
Applicable part numbers
B54103H2020A001
B54102H1020A001
Z63000Z2910Z 1Z 2
B54101H1020A001
Z63000Z2910Z1Z38
Z63000Z2910Z 1Z 5
Z63000Z2910Z 1Z 4
Z63000Z2910Z1Z39
Z63000Z2910Z1Z41
Z63000Z2910Z1Z42
495-77573-ND
495-77574-ND
495-76129-ND
495-77575-ND
Z63000Z2910Z1Z38-ND
495-76128-ND
495-76127-ND
495-77546-ND
495-77545-ND
Z63000Z2910Z1Z42-ND
Z63000Z2910Z1Z44
Z63000Z2910Z 1Z 7
Z63000Z2910Z 1Z 1
495-77434-ND
495-77246-ND
495-77245-ND
