Failed to enable BBB wifi
I met this problem on Beagleboneblack wireless and error log as below.
Could you help provide instructions on how to debug such problems?
Thanks in advance.
root@arm:~# connmanctl
connmanctl> enable wifi
Error wifi: Method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
connmanctl> scan wifi
Error /net/connman/technology/wifi: Method “Scan” with signature “” on interface “net.connman.Technology” doesn’t exist
connmanctl> services
connmanctl> agent on
Agent registered
connmanctl> quit
root@arm:~# uname -a
Linux arm 4.19.19-bone-rt-r21 #1 PREEMPT RT Mon Feb 11 15:17:49 CST 2019 armv7l GNU/Linux
root@arm:~# cat /etc/issue
Debian GNU/Linux 9 \n \l
default username:password is [debian:temppwd]
root@arm:~# cat /boot/uEnv.txt
uname_r=4.19.19-bone-rt-r21
optargs=quiet lpj=1990656
disable_uboot_overlay_video=1
disable_uboot_overlay_audio=1
disable_uboot_overlay_adc=1
uuid=cf9a32c1-ca83-4c8d-aec2-adc9d50334a9
root@arm:~#
Hello Springzhang, could you please provide the part number for the exact Beaglebone black you are referring to?
Sure. Can you tell me which cmd to fetch what you need?
Is BBBWL-SC-562-ND the part you are referring to? https://www.digikey.com/short/ppch49
@springzhang
Please run this command and share the output:
sudo /opt/scripts/tools/version.sh
Regards,
root@arm:~# /opt/scripts/tools/version.sh
git:/opt/scripts/:[702a85c3ea80bf39c36f539e40dbd0e877b173dc]
eeprom:[A335BNLTBWA51905BBWG0309]
model:[TI_AM335x_BeagleBone_Black_Wireless]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2018.09-dirty]:[location: dd MBR]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.09-00002-g0b54a51eee]:[location: dd MBR]
kernel:[4.19.19-bone-rt-r21]
pkg check: to individually upgrade run: [sudo apt install --only-upgrade ]
pkg:[bb-cape-overlays]:[4.4.20190123.0-0rcnee0~stretch+20190123]
WARNING:pkg:[bb-wl18xx-firmware]:[NOT_INSTALLED]
pkg:[kmod]:[23-2rcnee1~stretch+20171005]
WARNING:pkg:[librobotcontrol]:[NOT_INSTALLED]
pkg:[firmware-ti-connectivity]:[20180825+dfsg-1rcnee1~stretch+20181217]
groups:[debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users systemd-journal i2c netdev gpio pwm eqep bluetooth admin spi tisdk weston-launch xenomai cloud9ide]
cmdline:[console=ttyO0,115200n8 quiet lpj=1990656 root=UUID=cf9a32c1-ca83-4c8d-aec2-adc9d50334a9 ro rootfstype=ext4 rootwait]
dmesg | grep pinctrl-single
[ 0.632873] pinctrl-single 44e10800.pinmux: 142 pins, size 568
dmesg | grep gpio-of-helper
root@arm:~#
Additionally, I attach the kernel config for your reference in case I missed some driver during build kernel.
config-4.19.19-bone-rt-r21.txt (125.3 KB)
B.R.
I’ll test that kernel tomorrow…
This is an issue…
sudo apt update
sudo apt install --only-upgrade bb-wl18xx-firmware firmware-ti-connectivity
Regards,
which kernel can support wireless BBB? what’s the root cause for that issue? I guess I missed something during build kernel.
B.R.
Well let’s compare your config with what i offically shipped with: “4.19.19-bone-rt-r21”
git diff .config ~/Downloads/config-4.19.19-bone-rt-r21.txt > config.diff
-CONFIG_WLAN_VENDOR_TI=y
-CONFIG_WL1251=m
-CONFIG_WL1251_SPI=m
-CONFIG_WL1251_SDIO=m
-CONFIG_WL12XX=m
-CONFIG_WL18XX=m
-CONFIG_WLCORE=m
-CONFIG_WLCORE_SPI=m
-CONFIG_WLCORE_SDIO=m
-CONFIG_WILINK_PLATFORM_DATA=y
and
-CONFIG_WLAN=y
Yeap, you broke WiFi… Start again at the beginning and don’t go so crazy on disabling everything…
Regards,
I just finish “sudo apt install --only-upgrade bb-wl18xx-firmware firmware-ti-connectivit”
pkg:[bb-wl18xx-firmware]:[1.20190227.1-0rcnee0~stretch+20190227]
[ 0.632839] pinctrl-single 44e10800.pinmux: 142 pins, size 568
connmanctl>
Thanks so much. I will change to another image without kernel cutting.
sudo apt update
sudo apt install linux-image-4.19.19-bone-rt-r21
Regards,
I change to another image and still failed.
config-4.14.79-ti-rt-r86.txt (130.3 KB)
root@arm:~#
root@arm:~# pwd
/root
git:/opt/scripts/:[29878c8f9a13833ac69956ecc086c95b99726dde]
kernel:[4.14.79-ti-rt-r86]
pkg:[bb-cape-overlays]:[4.4.20180727.0-0rcnee0~stretch+20180727]
pkg:[librobotcontrol]:[1.0.4-git20190227.1-0rcnee0~stretch+20190327]
cmdline:[console=ttyO0,115200n8 quiet lpj=1990656 root=UUID=eefcaffa-1f67-46ee-8fe4-c3187c919829 ro rootfstype=ext4 rootwait]
[ 1.168593] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 1.170496] gpio-of-helper ocp:cape-universal: ready
END
root@arm:~# systemctl status bb-wl18xx-wlan0.service
● bb-wl18xx-wlan0.service - BB WL18xx wlan0 Service
Loaded: loaded (/lib/systemd/system/bb-wl18xx-wlan0.service; enabled; vendor
preset: enabled)
Active: activating (auto-restart) (Result: timeout) since Fri 2016-11-04 04:0
9:38 CST; 1s ago
Process: 17139 ExecStart=/usr/bin/bb-wl18xx-wlan0 (code=killed, signal=TERM)
Tasks: 0 (limit: 4915)
CGroup: /system.slice/bb-wl18xx-wlan0.service
Nov 04 04:09:38 arm systemd[1]: bb-wl18xx-wlan0.service: Unit entered fa
iled state.
Nov 04 04:09:38 arm systemd[1]: bb-wl18xx-wlan0.service: Failed with res
ult ‘timeout’.
root@arm:~# /usr/bin/bb-wl18xx-wlan0
wlan_0_mac=[00:00:00:00:00:00], this forces internal wl18xx mac address…
/lib/firmware/ti-connectivity/wl1271-nvs.bin=[00:00:00:00:00:00]
wl18xx:tether waiting for /sys/class/net/wlan0
Here’s the diff to your custom config-4.14.79-ti-rt-r86.txt…
-CONFIG_WL1251=m
-CONFIG_WL12XX=m
-CONFIG_WL18XX=m
-CONFIG_WLCORE=m
So YOU broke WiFI again. Feel free to use the “default” kernel configuration, which support these Single Board Computers by default…
sudo apt update
sudo apt install linux-image-4.14.79-ti-rt-r86
Regards,
Thanks much.
I just update the image and wifi works well.
How about the bluetooth failure? Did I miss something else?
root@arm:~# hciconfig -a
hci0: Type: Primary Bus: UART
BD Address: 18:62:E4:07:A5:4E ACL MTU: 1021:6 SCO MTU: 180:4
DOWN
RX bytes:3065 acl:0 sco:0 events:378 errors:0
TX bytes:73898 acl:0 sco:0 commands:379 errors:0
Features: 0xff 0xfe 0x2d 0xfe 0xdb 0xff 0x7b 0x87
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF
Link mode: SLAVE ACCEPT
root@arm:~# sdptool browse local
Failed to connect to SDP server on FF:FF:FF:00:00:00: No such file or directory
root@arm:~# hcitool scan
Device is not available: No such device
root@arm:~# hciconfig hci0 iscan
Can’t set scan mode on hci0: Network is down (100)
root@arm:~# dmesg | grep tooth
[ 13.639249] Bluetooth: Core ver 2.22
[ 13.639384] Bluetooth: HCI device and connection manager initialized
[ 13.639407] Bluetooth: HCI socket layer initialized
[ 13.639417] Bluetooth: L2CAP socket layer initialized
[ 13.639456] Bluetooth: SCO socket layer initialized
[ 13.797317] Bluetooth: HCI UART driver ver 2.3
[ 13.797331] Bluetooth: HCI UART protocol H4 registered
[ 13.797417] Bluetooth: HCI UART protocol LL registered
[ 13.797423] Bluetooth: HCI UART protocol ATH3K registered
[ 13.797476] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.913823] Bluetooth: hci0: change remote baud rate command in firmware
[ 17.283909] Bluetooth: hci0: command 0xff05 tx timeout
[ 25.315898] Bluetooth: hci0: send command failed
[ 25.320606] Bluetooth: hci0: download firmware failed, retrying…
[ 25.485396] Bluetooth: hci0: change remote baud rate command in firmware
root@arm:~# systemctl status bb-wl18xx-bluetooth.service
● bb-wl18xx-bluetooth.service - BB WL18xx Bluetooth Service
Loaded: loaded (/lib/systemd/system/bb-wl18xx-bluetooth.service; enabled; vendor preset: en
abled)
Active: inactive (dead) since Mon 2019-02-11 00:00:09 CST; 3min 55s ago
Process: 607 ExecStart=/usr/bin/bb-wl18xx-bluetooth (code=exited, status=0/SUCCESS)
Feb 11 00:00:06 arm systemd[1]: Starting BB WL18xx Bluetooth Service…
Feb 11 00:00:09 arm bb-wl18xx-bluetooth[607]: Can’t open serial port: No such file or director
y
Feb 11 00:00:09 arm bb-wl18xx-bluetooth[607]: Can’t initialize device: No such file or directo
ry
Feb 11 00:00:09 arm systemd[1]: Started BB WL18xx Bluetooth Service.
[ 0.596195] pinctrl-single 44e10800.pinmux: 142 pins, size 568
root@arm:~# systemd-analyze blame
13.932s bb-wl18xx-wlan0.service
7.438s dev-mmcblk0p1.device
7.135s generic-board-startup.service
3.135s bb-wl18xx-bluetooth.service
1.192s ssh.service
1.190s systemd-udev-trigger.service
729ms systemd-journald.service
591ms connman.service
588ms systemd-rfkill.service
492ms systemd-remount-fs.service
398ms wpa_supplicant.service
316ms hostapd.service
308ms systemd-tmpfiles-setup-dev.service
300ms systemd-udevd.service
273ms systemd-sysctl.service
260ms sys-kernel-config.mount
257ms systemd-logind.service
249ms dev-mqueue.mount
248ms user@0.service
244ms systemd-user-sessions.service
240ms sys-kernel-debug.mount
214ms systemd-update-utmp.service
200ms systemd-modules-load.service
196ms kmod-static-nodes.service
192ms systemd-journal-flush.service
170ms rc-local.service
167ms sys-fs-fuse-connections.mount
127ms systemd-tmpfiles-setup.service
110ms systemd-random-seed.service
65ms systemd-update-utmp-runlevel.service
The current default image: http://beagleboard.org/latest-images
debian@beaglebone:~$ uname -r
4.14.71-ti-r80
debian@beaglebone:~$ bluetoothctl
[NEW] Controller 98:7B:F3:13:30:C8 beaglebone [default]
[bluetooth]# scan on
Discovery started
[CHG] Controller 98:7B:F3:13:30:C8 Discovering: yes
[NEW] Device 4E:FB:D7:56:77:7B 4E-FB-D7-56-77-7B
[NEW] Device 56:D5:3E:02:5B:F7 56-D5-3E-02-5B-F7
[NEW] Device 5C:F3:70:8E:75:74 DESKTOP-TJ4283Q
[bluetooth]# exit
[DEL] Controller 98:7B:F3:13:30:C8 beaglebone [default]
debian@beaglebone:~$ dmesg | grep tooth
[   88.761989] Bluetooth: Core ver 2.22
[   88.762217] Bluetooth: HCI device and connection manager initialized
[   88.762251] Bluetooth: HCI socket layer initialized
[   88.762266] Bluetooth: L2CAP socket layer initialized
[   88.762321] Bluetooth: SCO socket layer initialized
[   88.868848] Bluetooth: HCI UART driver ver 2.3
[   88.868871] Bluetooth: HCI UART protocol H4 registered
[   88.880708] Bluetooth: HCI UART protocol LL registered
[   88.880727] Bluetooth: HCI UART protocol ATH3K registered
[   88.880734] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   88.880740] Bluetooth: HCI UART protocol QCA registered
[   90.111596] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   90.111614] Bluetooth: BNEP filters: protocol multicast
[   90.111650] Bluetooth: BNEP socket layer initialized
debian@beaglebone:~$ systemctl status bb-wl18xx-bluetooth.service
   Active: active (running) since Fri 2019-04-12 17:06:28 UTC; 51s ago
  Process: 2104 ExecStart=/usr/bin/bb-wl18xx-bluetooth (code=exited, status=0/SU
 Main PID: 2155 (hciattach)
    Tasks: 1 (limit: 4915)
   CGroup: /system.slice/bb-wl18xx-bluetooth.service
           └─2155 /usr/bin/hciattach /dev/ttyS3 texas 300000
Apr 12 17:06:21 beaglebone systemd[1]: Starting BB WL18xx Bluetooth Service...
Apr 12 17:06:22 beaglebone bb-wl18xx-bluetooth[2104]: Found a Texas Instruments'
Apr 12 17:06:22 beaglebone bb-wl18xx-bluetooth[2104]: Firmware file : /lib/firmw
Apr 12 17:06:22 beaglebone bb-wl18xx-bluetooth[2104]: Loaded BTS script version
Apr 12 17:06:22 beaglebone bb-wl18xx-bluetooth[2104]: texas: changing baud rate
Apr 12 17:06:28 beaglebone bb-wl18xx-bluetooth[2104]: Device setup complete
Apr 12 17:06:28 beaglebone systemd[1]: Started BB WL18xx Bluetooth Service.
and with 4.19.19-bone-rt-r21
4.19.19-bone-rt-r21
[NEW] Device 4B:38:82:0E:15:C3 4B-38-82-0E-15-C3
[NEW] Device 41:01:23:24:A9:08 41-01-23-24-A9-08
Discovery started
[CHG] Device 41:01:23:24:A9:08 RSSI: -85
[NEW] Device 6B:E8:E9:1E:43:7C 6B-E8-E9-1E-43-7C
[bluetooth]# exit
[  108.982024] Bluetooth: Core ver 2.22
[  108.982156] Bluetooth: HCI device and connection manager initialized
[  108.982177] Bluetooth: HCI socket layer initialized
[  108.982186] Bluetooth: L2CAP socket layer initialized
[  108.982219] Bluetooth: SCO socket layer initialized
[  109.013785] Bluetooth: HCI UART driver ver 2.3
[  109.013798] Bluetooth: HCI UART protocol H4 registered
[  109.013877] Bluetooth: HCI UART protocol LL registered
[  109.013881] Bluetooth: HCI UART protocol ATH3K registered
[  109.013923] Bluetooth: HCI UART protocol Three-wire (H5) registered
[  109.263269] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  109.263280] Bluetooth: BNEP filters: protocol multicast
[  109.263301] Bluetooth: BNEP socket layer initialized
   Active: active (running) since Fri 2019-04-12 17:15:05 UTC; 57s ago
  Process: 2005 ExecStart=/usr/bin/bb-wl18xx-bluetooth (code=exited, status=0/SU
 Main PID: 2035 (hciattach)
           └─2035 /usr/bin/hciattach /dev/ttyS3 texas 300000
Apr 12 17:15:03 beaglebone systemd[1]: Starting BB WL18xx Bluetooth Service...
Apr 12 17:15:03 beaglebone bb-wl18xx-bluetooth[2005]: Found a Texas Instruments'
Apr 12 17:15:03 beaglebone bb-wl18xx-bluetooth[2005]: Firmware file : /lib/firmw
Apr 12 17:15:03 beaglebone bb-wl18xx-bluetooth[2005]: Loaded BTS script version
Apr 12 17:15:03 beaglebone bb-wl18xx-bluetooth[2005]: texas: changing baud rate
Apr 12 17:15:05 beaglebone bb-wl18xx-bluetooth[2005]: Device setup complete
Apr 12 17:15:05 beaglebone systemd[1]: Started BB WL18xx Bluetooth Service.
So feel free to utilize the default kernel config, your still cutting too much…
Start with the base config and on each removal retest…
Regards,
I follw the below procudure to make totall new image without any cutting.
It seems there missed some bluetooth protocol support and I am not clear whether need to enable some config during building kernel or need apt install some extra pkg.
Thanks for your support.
https://www.digikey.com/eewiki/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-Setuname_rin/boot/uEnv.txt.
config4.14.93-bone-rt-r17.txt (150.7 KB)
root@arm:/boot# /opt/scripts/tools/version.sh
git:/opt/scripts/:[38ce81fcdafad0892b6c485acd4e9a2245dfb07a]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2019.01-dirty]:[location: dd MBR]
kernel:[4.14.93-bone-rt-r17]
uboot_overlay_options:[enable_uboot_overlays=1]
uboot_overlay_options:[enable_uboot_cape_universal=1]
pkg:[bb-cape-overlays]:[4.4.20190215.0-0rcnee0~stretch+20190215]
cmdline:[console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 optargs=quiet lpj=1990656]
[ 0.457168] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.462742] gpio-of-helper ocp:cape-universal: ready
END
root@arm:/boot# dmesg |grep tooth
[ 9.369276] Bluetooth: Core ver 2.22
[ 9.480157] Bluetooth: HCI device and connection manager initialized
[ 9.514612] Bluetooth: HCI socket layer initialized
[ 9.593102] Bluetooth: L2CAP socket layer initialized
[ 9.650258] Bluetooth: SCO socket layer initialized
[ 20.095689] Bluetooth: HCI UART driver ver 2.3
[ 20.114109] Bluetooth: HCI UART protocol H4 registered
[ 20.125525] Bluetooth: HCI UART protocol ATH3K registered
[ 20.135065] Bluetooth: HCI UART protocol Three-wire (H5) registered
root@arm:/boot# systemctl status bb-wl18xx-bluetooth.service
t: enabled)
Active: inactive (dead) since Mon 2019-04-15 15:17:18 CST; 27min ago
Process: 678 ExecStart=/usr/bin/bb-wl18xx-bluetooth (code=exited, status=0/SUCCESS)
Apr 15 15:17:17 arm systemd[1]: Starting BB WL18xx Bluetooth Service…
Apr 15 15:17:17 arm bb-wl18xx-bluetooth[678]: Found a Texas Instruments’ chip!
Apr 15 15:17:17 arm bb-wl18xx-bluetooth[678]: Firmware file : /lib/firmware/ti-connectivi
ty/TIInit_11.8.32.bts
Apr 15 15:17:17 arm bb-wl18xx-bluetooth[678]: Loaded BTS script version 1
Apr 15 15:17:17 arm bb-wl18xx-bluetooth[678]: texas: changing baud rate to 3000000, flow
control to 1
Apr 15 15:17:18 arm bb-wl18xx-bluetooth[678]: Can’t set device: Protocol not supported
Apr 15 15:17:18 arm bb-wl18xx-bluetooth[678]: Can’t initialize device: Protocol not suppo
rted
Apr 15 15:17:18 arm systemd[1]: Started BB WL18xx Bluetooth Service.
root@arm:/boot#
@springzhang
I’m confused, what guide are you following? You’ve jumped between, 4.19.19-bone-rt-r21, 4.14.79-ti-rt-r86, and now 4.14.93-bone-rt-r17…
and yes, i can confirm 4.14.93-bone-rt-r17 shows this issue:
4.14.93-bone-rt-r17
debian@beaglebone:~$ journalctl | grep bb-wl18xx-bluetooth
Apr 15 15:25:32 beaglebone bb-wl18xx-bluetooth[1056]: Found a Texas Instruments' chip!
Apr 15 15:25:32 beaglebone bb-wl18xx-bluetooth[1056]: Firmware file : /lib/firmware/ti-connectivity/TIInit_11.8.32.bts
Apr 15 15:25:32 beaglebone bb-wl18xx-bluetooth[1056]: Loaded BTS script version 1
Apr 15 15:25:32 beaglebone bb-wl18xx-bluetooth[1056]: texas: changing baud rate to 3000000, flow control to 1
Apr 15 15:25:33 beaglebone bb-wl18xx-bluetooth[1056]: Can't set device: Protocol not supported
Apr 15 15:25:33 beaglebone bb-wl18xx-bluetooth[1056]: Can't initialize device: Protocol not supported
But at this point, you should be using v4.19.x anyways…
Regards,
Sorry. Let me make it more clear.
My goal is to make minimal RTLinux image with booting time as short as possible.
I had built two versions of 4.19.19-bone-rt-r21, 4.14.79-ti-rt-r86 with some cutting before as the below procedure for beagleboneblack Rev C.
For now, I change to beagleboneblack wireless and I try to use previous image but failed to enable bluetooth.
So as your instructions, I just rebuild the image of 4.14.93-bone-rt-r17 without any cutting and show issues above.
Could you tell me how to go ahead at this point?
1, apt install linux-image-4.19.19-bone-rt-r21 on top of 4.14.93-bone-rt-r17
2, rebuild new image of linux-image-4.19.19-bone-rt-r21?
3, any other fix?
Thanks much!
For your reference.
I apt install linux-image-4.19.19-bone-rt-r21 on top of 4.14.93-bone-rt-r17 but happen another error.
Finally I find the below solution
change value from 1 to 0 in this file /var/lib/systemd/rfkill/platform-481a6000.serial:bluetooth.
root@arm:/var/lib/systemd/rfkill# systemctl status bb-wl18xx-bluetooth.service
   Loaded: loaded (/lib/systemd/system/bb-wl18xx-bluetooth.service; enabled; vendor preset: enabled)
   Active: inactive (dead) since Fri 2016-11-04 01:18:42 CST; 3min 36s ago
  Process: 1071 ExecStart=/usr/bin/bb-wl18xx-bluetooth (code=exited, status=0/SUCCESS)
Nov 04 01:18:39 arm systemd[1]: Starting BB WL18xx Bluetooth Service...
Nov 04 01:18:40 arm bb-wl18xx-bluetooth[1071]: Found a Texas Instruments chip!
Nov 04 01:18:40 arm bb-wl18xx-bluetooth[1071]: Firmware file : /lib/firmware/ti-connectivity/TIInit_11.8.32.bts
Nov 04 01:18:40 arm bb-wl18xx-bluetooth[1071]: Loaded BTS script version 1
Nov 04 01:18:40 arm bb-wl18xx-bluetooth[1071]: texas: changing baud rate to 3000000, flow control to 1
Nov 04 01:18:42 arm bb-wl18xx-bluetooth[1071]: Can't init device hci0: Operationnot possible due to RF-kill (132)Can't initialize device: Operation not possible due to RF-kill
Nov 04 01:18:42 arm systemd[1]: Started BB WL18xx Bluetooth Service.
