WIFI connection failed
Hi Robert,
I have hard time to configure WIFI. Using connmanctl, scan, … all ok. access points are listed.
To connect one without password required:
it fails:
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“FRC_Guest” auth_failures=1 duration=10 reason=CONN_FAILED
To Connect one with password required:
It also fails:
wlan0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid=“FRC_STAFF” auth_failures=1 duration=10 reason=CONN_FAILED
The wlan0 is active under ifconfig.
is etc/wpa_supplicant.conf required?
(LInux version: 4.19.50-ti-r20)
Thank you,
David
Hi Robert,
Finally, I figured out. It was antenna problem on our board.
Thank you,
David
Hi @dzhou, are you using the same Dual Antenna approach as the BBBW?
If not, here the firmware and a hint on how to rebuild it for your antenna…
Think FCC Testing. :wink:
Regards,
Hi Robert,
We are using dual antenna. Thank you for your info.
Regards,
David
