FD249225EB is a DC brushless fan rated at 24VDC and 0.27A. It is 90mm x 90mm x 25mm in size. It is from Y.S. Tech and Digi-Key does not carry that fan.
We do have a fan that would work as an alternative. It’s size is 92mm x 92mm x 25mm, but as long as the size works in your application, then it will work as a cross. It is Digi-Key part number 3610VL-05W-B60-B00-ND.
Please refer to the data sheet and specifications to verify if it will work for your application.
