Find a linear voltage regulator outputs are +/- 2.5V
Hi,
i try to find a linear voltage regulator outputs are +/- 2.5V. The power supply( input voltage) will be +/-5V.
Hi,
Welcome to the Digikey tech forum. I wasn’t able to find an option matching the information you listed. Take a look through these regulators to see if you can one or a combination of these for your application.
