FW version in the BG95M5
The Quectel BG95M5 you have on stock, which FW. version is that?
Multiple items come up when I search for that, do you have a full manufacturer part number or DigiKey number?
OK here is the full Quectel partnumber BG95M5LA-64-SGNS// Digi 2958-BG95M5LA-64-SGNSTR-ND
Are you in the EU region? If you are, you should refer to this document, click here. It sates the following, “The document Impacted_OC_and_Firmware_Version_List_for_Quectel_PCN provides the ordering codes
and firmware versions for all affected products. For more details, please contact Quectel Technical Support
at support@quectel.com or Quectel’s Commercial Department.” I can ask if we have received specific firmware versions, but I think that only applies to the EU and we have just the base parts, so I assume the default firmware version they initially released would be pre-installed.
OK Thank you
Enjoy your week-end
