FXUWB20.01.0100C
Question for FXUWB20.01.0100C Please Put your question below------
Good morning
I would like to know if this type of antenna is installed horizontally inside a ground-level junction box under a metal cover.
Thank you.
Hello @david.mohino
Welcome to the Community!
The antenna is designed to be adhered directly onto a non-metal surface** (e.g., plastic or glass) using tape/adhesive and not intended to be placed flat against metal.
The datasheet recommends keeping it at least 10 mm clear from metal, and ideally 20 mm for best radiation efficiency.
FXUWB20.01.0100C Specification by Taoglas Limited Datasheet | DigiKey
