Molex 2068663000 antenna orientation
What is the orientation of this antenna
model in particular. Whether the smoother
side face the sky or towards the ground?
for efficient GNSS/GPS satellite coverage.
The XY axis is going to give you the best reception.
From page 7 of the Application Specification, it shows the following:
As I interpret this, the adhesive foam side is intended to face up. I presume this means that it should be mounted to the underside of a non-RF-shielding flat surface.
Thank you for the response
