For the pin name: I2C2_SCL, if the port is MODE3, it matches the Header P9 name. Does that imply the pin is in MODE3?
In the /sys/class/gpio:
There is no mode for R/W. Does that imply the pin is in GPIO mode, which is MODE7.
Just for this GPIO0_13 pin, how do I know what is the current PIN function? Or is there a way to confirm or to switch the pin modes?
I configured the pin as output through /sys/class/gpio/gpio13, but it doesn’t toggle. Is it possible that the pin is used by some other driver as I2C2_SCL.
MODE3 is a TI specific configuration for this AM335x, it is not show in a “generic” way under /sys/class/gpio/… Our show-pin’s script does a lookup under debugfs to determine what mode it’s under…
If you want to use GPIO0_13 in gpio mode, disable the i2c/pinmux in the device tree and define it in your device tree as a gpio/led/etc…
Nope, it’s in a ‘reset’ state, which varies between i/o on the AM335x, these reset states are listed in the AM335x reference manual…
