Does Digi-Key have any AC-to-DC grounded plug-in power supplies? We can use 6VDC, 9VDC, or 12VDC output, 100mA or more. A 5.5mm x 2.1mm plug would be good.
The problem is that we get humming from the microphones in Koss headsets (but not Logitek and Sennheiser headsets).
I’m actually finding a number of devices that appear to meet the requested criteria here. While most such products do indeed use a 2-conductor input plug, those with 3 can be identified on the basis of the input connector used
Thanks. Can I make a suggestion? Can you add an option-select column for grounded? Trying to identify grounded AC adapters by electrical plug isn’t easy.
