This post is for informational purposes only. Please review the manufacturer’s datasheet to verify that any recommended parts are suitable for your application.
I was recently asked about a power supply, used in GSK980 CNC machines, part number GSKPB2/PC2. Detailed information was hard to come by for this but the basic specs can be found on third party sites such as CNCmakers.
This is not a direct cross, but part number 1866-4112-ND from Mean Well should be a reasonable alternative if you need something in stock. I selected this because the output voltages match the original and the maximum power meets or exceeds them, but you should review the features carefully to make sure it is compatible with your machine if you are using it for repair or retrofit purposes.
