Can this switch be hardwired in my homes electrical to control a light?
SWITCH ROCKER SPDT 16A 125V
PART: 401-1299-ND
MFG : C&K / CR101J11S115QF
PART: 401-1299-ND
Hello @jason_t_holmes
The switch 401-1299-ND can electrically handle home lighting loads based on its 125/250 VAC rating, but the datasheet does not specifically indicate that it is approved for permanent residential installations. It is primarily intended for appliances and equipment.
However, you should share details about how you want to use this, may be someone from our team can help better.
Thank you for your feedback. I want to use the switches to power sconces in a custom bed head board im building. The light fixtures are 120v.
