Harting connector
Please tell me the part numbers for this harting connector pins and housing.
I have found part 09330162301 for the pins and 19300161522 for the housing. Not sure if that is correct. I also found a kit 10330160000 not sure if that is correct and better option.
Hello @acoffell,
Welcome to the TechForum!
Let’s look at the Harting 10330160000 kit. The lower right-hand corner of the datasheet presents the part numbers for the individual pieces including the cable gland.
With respect to the number you provided, 09330162301 seems out of place.
To square this circle, I recommend focusing on the other side of the equation. Please verify that the part numbers for the female insert and housing match the part numbers in the image. If they do, we have high confidence that the correct HARTING series has been found.
Looking forward to your reply,
