Help for project
I doing a project for school and I wanted to make sure the items I’m buying will able to work together.
I have two pmods:
https://store.digilentinc.com/pmodwifi-wifi-interface-802-11g/
And a piezo sensor:
Will the piezo sensor be able to work with both of them?
Thank you.
@johnsan1,
Do you have another device, of which is not listed above? The piezo sensor you listed must be driven by something, your two other devices are a wifi interface and a sensor (thermocouple). You’d need something to drive these 3 devices.
Regards,
Yes, I am also using a nexys a7: fpga trainer board.
The ADC’s on that board can not handle signals from that sensor without some form of signal conditioning…
Take a look at this article:
https://www.digikey.com/en/articles/techzone/2011/dec/fundamentals-of-piezoelectric-shock-and-vibration-sensors
Regards,
Ok so a few questions.
How would you interface the op amps to this project? Also once I am able to connect the op amp to the piezo sensor, everything else should work fine right?
Thank you so much for helping me.
@johnsan1, if you don’t want to design your own circuit, I believe you could use this pmod adapter:
https://www.digikey.com/products/en?keywords=EVAL-CN0350-PMDZ-ND
Regards,
