Help - we are looking for a compatible part for PCI9030AA60PI which is a PCI-local bus interface chip for an existing design.
Digikey page is : PCI9030-AA60PI F Broadcom Limited | Integrated Circuits (ICs) | DigiKey
My engineer says that the Substitutes as listed on this page are pretty different parts.
Can anyone suggest a true compatible part ?
Or, source of stock to bridge us to our next design ?
Thank you for your post.
The potential substitute listed at the bottom of the page for that part are classified as similar parts and are not always guaranteed to be a drop-in replacement. They are often times our closest options, but normally need to be reviewed to see if they will work for your application.
Upon taking a closer look for a better substitute, I was not able to find an option that could directly replace the original part.
