I was trying to find more of these, they originally came from here so hopefully you’ll have a updated part.
Thanks, John
Thanks, John
Hello Classic079,
thank you for posting on our forum and welcome to our community.
PN 1754-1399-ND was the closest cross I found.
I’m sorry, I should have put the picture of the part in the post but here you go. The plug is different on the KTM one than anything else I’ve seen.
classic079
Thank you for contacting DigiKey , It looks like this part may be available please call our sales team at 1-800-344-4539 and give them the part number KTMDCD-06PMFS-QC8 .
Thanks Craig
I called this morning and they couldn’t find it and told me to post here to find it. Unless I’m missing something that is the same PN on the invoice right? That is what I gave them and they said it wasn’t in the system unless she understood it right. Thank you for all your help!
The P/N exists, though it’s presently unlisted/non-stock/NCNR terms, and I don’t really see anything in the current catalog that suggests present availability of a 2+4 configuration. (it’d be around p.133)
That was probably a non-catalog order to start with. If one has leeway to do so it may be advantageous to swap everything out for another model that’s available from stock, since it’s unlikely that getting more will be a quick affair. (one doesn’t necessarily have to use all the pins on a connector…)
If you don’t have that freedom, I’d call the sales folks again and tell them that you want to re-order a non-catalog item, requesting a supervisor or different agent if the one initially responding is unable to assist.
