Help with part numbers
looking for two parts. Both Film Capacitors Axial .022 600V and .1 600v can you help with part numbers
we do not have any at those ratings that are axial , here is what we do have,
0.022 µF Film Capacitors | Electronic Components Distributor DigiKey
Here’s a link to some axial film caps to consider. These are all rated for at least 600Vdc (note that the AC voltage rating is typically significantly lower):
> 600Vdc 0.022uF caps
> 600Vdc 0.1uF caps
