This connector measures ~7.5mm wide. I need the part number for the mating socket and pins.
Thank you
Welcome to the Digi-Key TechForum nick1.
I believe the connector in the picture, would be like 455-1639-ND.
So the mating connector housing would be 455-3989-ND.
Click here for the available contacts, for that connector.
If you want to use Pre-Crimped leads, Click here for available options.
Please check the datasheets for compatibility to your application.
