I would like to ask whether the HMC747 T trigger is level trigger or edge trigger.
According to the description of datashee, it should be edge trigger, but when I was doing experiments, I found that it should be in line with level trigger. When CP is continuously high and there is no level change, the level conversion of DP can be sent to QP
我想请问一下HMC747 T触发器是电平触发还是边沿触发。
根据datashee的描述应该是边沿触发,但是我在做实验时发现,他应该是符合电平触发。CP端持续为高时并且没有电平变化,DP端的电平变换能够送到QP端
