The Honeywell E-Stop switch 50093979-05-ND and 50058830-05 comes with an attached Deutsch connector part number DT-04-4P. The mating connector, wedge lock, and crimp contacts that are sold separately are Deutsch DT06-4S(housing), Deutsch part W4S(Wedge Lock) and click here for the crimp contacts. The mating connector will need all 3 pieces for the assembly. You can find the tooling by searching the crimp contact you chose on TE Connectivity’s website https://www.te.com/.
| Digi-Key Part Number | 50093979-05-ND | |
| Manufacturer | Honeywell Sensing and Productivity Solutions | |
| Manufacturer Product Number | 50093979-05 | |
| Description | PUSH PULL SWITCH | |
| Datasheet | 50093979-05 Spec Sheet |
| Digi-Key Part Number | 50058830-05-ND | |
| Manufacturer Product Number | 50058830-05 | |
