Sometimes you may find yourself confused over how to evaluate Sensirion’s environmental sensors, such as the SHT35-DIS-B2.5KS Humidity and Temperature Sensor. Is there any evaluation kit that allows you to connect up to a computer for evaluation?
The answer is simple. Get the SEK-SensorBridge evaluation kit, its required SEK-Evaluation-Sensor board, and download some software (SEK-ControlCenter) to start making measurements.
SEK-Evaluation-Sensors comes with the required connector cable. Each environmental sensor has a corresponding SEK-Evaluation-Sensor board as below.
Please clickhere to check out Sensirion’s Environment Sensing SEK Overview and familiarize yourself with the SEK-Environmental Sensing toolbox.
Applicable Part Numbers
SEK-SENSORBRIDGE
1649-SEK-SENSORBRIDGE-ND
SEK-SHT31-SENSORS
1649-SEK-SHT31-SENSORS-ND
SEK-SHT35-SENSORS
1649-SEK-SHT35-SENSORS-ND
SEK-SHTC3-SENSORS
1649-SEK-SHTC3-SENSORS-ND
SEK-SHTW2-SENSORS
1649-SEK-SHTW2-SENSORS-ND
SEK SCC30-DB SAMPLE
1649-1112-ND
SEK-SGP30-SENSORS
1649-SEK-SGP30-SENSORS-ND
SEK-SGPC3-SENSORS
1649-SEK-SGPC3-SENSORS-ND
SEK-SVM30
1649-1121-ND
SEK-SCD30-SENSOR
1649-SEK-SCD30-SENSOR-ND
SEK-SPS30
1649-1107-ND
