How to use Magnetic Buzzer Transducer
Hey guys!
So I recently got this audio buzzer, DigiKey Part 102-1458-ND
I am having some trouble getting it to work. Can I ground it and give it 3V, or do I have to enable it in the code?
Thanks!
Hi @nweixelman, CUI has a good Application Note, which may help answer some of your questions:
Most importantly is:
My biggest questions, do you have a diode in parallel with the CUI CST-931AP?
There’s also a good example on the bottom of page 2:
Regards,
I did see that diode, but it didn’t give me a value or part of one to order.
Do you know of one that would work?
Thanks!
Hi @nweixelman , just standard diode like:
Should work fine..
Regards,
