HRWB101 Power Distribution Strip
The DigiKey 4048-HRWB101-ND (HRWB101) is a 5-port DC outlet strip designed for powering 12 VDC equipment. It provides one input and five outputs, using standard Anderson PowerPole 15-45 connectors. Individually fused outputs using Automotive ATO/ATC type fuses, and there is a built-in LED that indicates when external power is applied.
Sold as a kit. Tools needed for assembly are Soldering iron, solder, wire cutters, and Philips screwdriver. It is recommended to use a soldering iron with a large chisel tip.
Tools-
1691-1002-ND
RASWLF.0311OZ-ND (RASWLF.031 1OZ)
1691-1037-ND (CHP-170)
431-1104-ND
To assemble, please follow the assembly instructions
Additional components are Anderson 15-45 series connectors, 6 red and black. Along with 12 contacts, crimp tool, and wire. The associated parts are -
2243-1327-ND
2243-1327G6-ND
2243-261G2CT-ND “10-14AWG”
2243-1309G3-ND
