i.MX6x SABRE Lite SPI Flash Recovery
Setup Recovery Media
These images where extracted from:
wget https://rcn-ee.net/deb/tools/mx6qsabrelite/factory/u-boot-2014-04/u-boot.mx6qsabrelite
Format microSD/SD card:
For these instruction, we are assuming: DISK=/dev/mmcblk0, “sudo fdisk -l” is useful for determining the device id…
export DISK=/dev/mmcblk0
Erase microSD/SD card:
sudo dd if=/dev/zero of=${DISK} bs=1M count=30
Create Partition Layout:
sudo sfdisk --in-order --Linux --unit M ${DISK} <<-__EOF__
1,20,0x83,-
__EOF__
Format Partitions:
for: DISK=/dev/mmcblk0
sudo mkfs.ext2 ${DISK}p1 -L boot
for: DISK=/dev/sdX
sudo mkfs.ext2 ${DISK}1 -L boot
Mount Partitions:
On some systems, these partitions may be auto-mounted…
sudo mkdir -p /media/boot/
sudo mount ${DISK}p1 /media/boot/
for: DISK=/dev/sdX
sudo mount ${DISK}1 /media/boot/
Copy Factory Images to microSD/SD card:
sudo cp -v u-boot.mx6qsabrelite /media/boot/v2014.04.imx
Remove microSD/SD card:
sync
sudo umount /media/boot
Upgrade factory v2009.08 → factory v2014.04
Set mmcdev based on what microSD/SD device you are using
using: SD media
setenv mmcdev 0
using: microSD media
setenv mmcdev 1
Load v2013.04.imx and flash to SPI
mmc dev ${mmcdev}
ext2load mmc ${mmcdev}:1 0x10800000 v2014.04.imx
sf probe 1 27000000
sf erase 0 0xc0000
sf write 0x10800000 0x400 ${filesize}
Remove power, microSD/SD, and re-apply power.
Upgrade factory v2013.04 → factory v2014.04
using: SD media
setenv mmcdev 0
setenv mmcdev 1
Load v2014.04.imx and flash to SPI
mmc dev ${mmcdev}
sf probe
sf erase 0 0xc0000
Restore Bootloader via USB
Move SW1 from 00 → 01 (usb otg) to boot from usb-otg…
Note: it helps not have any microSD/SD card inserted into the board during powerup on…
lsusb:
Bus 008 Device 007: ID 15a2:0054 Freescale Semiconductor, Inc. i.MX6Q SystemOnChip in RecoveryMode
Build imx_usb_loader
sudo apt-get -y install build-essential libusb-1.0-0 libusb-1.0-0-dev
git clone git://github.com/eewiki/imx_usb_loader.git
cd imx_usb_loader/
make
Restoring: v2014.04
With imx_usb, select u-boot.nitrogen6q
cd imx_usb_loader/
sudo ./imx_usb ../u-boot.nitrogen6q
Insert mmc device into board:
using: SD media
setenv mmcdev 0
setenv mmcdev 1
mmc dev ${mmcdev}
sf probe
sf erase 0 0xc0000
Flashing Log:
U-Boot > setenv mmcdev 1
U-Boot > mmc dev ${mmcdev}
mmc1 is current device
U-Boot > load mmc ${mmcdev}:1 0x10800000 v2013.04.imx
338164 bytes read in 103 ms (3.1 MiB/s)
U-Boot > sf probe
SF: Detected SST25VF016B with page size 4 KiB, total 2 MiB
U-Boot > sf erase 0 0xc0000
U-Boot > sf write 0x10800000 0x400 ${filesize}
U-Boot >
Remove power, usb cable, microSD/SD, move jumper back to 00, and re-apply power.
U-Boot 2013.04-00308-ge1290a7 (Jun 18 2013 - 13:38:20)
CPU:   Freescale i.MX6Q rev1.0 at 792 MHz
Reset cause: POR
Board: SABRE Lite
DRAM:  1 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
No panel detected: default to HDMI
enable_hdmi: setup HDMI monitor
Display: HDMI (1024x768)
In:    serial
Out:   serial
Err:   serial
Net:   using phy at 6
FEC [PRIME]
Warning: failed to set MAC address
Hit any key to stop autoboot:  0
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: ncq stag pm led clo only pmp pio slum part
No port device detected!
** Bad device size - sata 0 **
SATA device 1: unknown device
** Bad device sata 1 **
MMC: no card present
mmc0(part 0) is current device
** Bad device mmc 0 **
mmc1(part 0) is current device
** Bad device mmc 1 **
6x_bootscript not found
serial console at 115200, 8N1
details at http://boundarydevices.com/6q_bootscript
(Re)start USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
U-Boot >
Comments
Any questions or comments please go to our TechForum: TechForum
