Hi,
I have basic SabreSD Board, and I followed the instructions here and have some issues:
[Sabre Board](https://eewiki.net/display/linuxonarm/i.MX6q+SABRE+Board+for+Smart+Devices)
I have a Ubuntu 14.04 LTS (updated to latest) as a guestOS inside
VMWorkstation Pro 12 with util-linux == 2.20.1
I performed all of the steps and tried the SDCard in my system.
and put sdcard into my sabre board. Upon power-up - there was no output at all
(no u-boot or any console output)
I am not sure I understand the sfdisk scripts. When executed - it only created
a single ext4 partition?
I then found a version of imx Linux user guide and followed those instructions in
constructing the sdflash partitioning:
[imx6 linux user guide](https://community.nxp.com/servlet/JiveServlet/download/571486-1-362556/i.MX_Linux_User's_Guide.pdf)
After manually doing this - and install the built u-boot.imx and copying the zImage and
dtbs to the first partition (starting @ 20480), and install the rootfs in the second ext4
partition (as well as following the eewikii installation instructions). -
This succeeded in booting - but I have some issues with no output to the HDMI.
I am wondering what are the issues with subject line instructions for my setup?
Thanks in advance!
Tom
Update:
Using a manual process - I created a single ext4 partition
and that worked too.
So, it was just the sfdisk utils that are mal-configured
(and that it isn’t outputting HDMI)
Hi Tom,
We’ve been fighting sdcard mis-writes caused by Virtualization software (VMware/VirtualBox/etc) for a long time. A native install of 14.04 would probably create the sdcard correctly. (Although i only test Ubuntu 16.04 and Debian Stretch at this point in time).
Just finished testing v4.1.x & v4.4.x, video is broken, even when trying to force it via: [video=HDMI-A-1:1024x768@60e]
As v4.9.x will need a few changes (just like Wandboard) for the mmc card node name, i’m working updating u-boot right now.
Regards,
I’ve updated u-boot to v2017.01 and added v4.9.x, video still doesn’t work, but we are getting hints now:
[ 5.718584] [drm] forcing HDMI-A-1 connector ON
[ 5.723555] imx-drm display-subsystem: bound 120000.hdmi (ops dw_hdmi_imx_ops)
[ 5.738419] imx-drm display-subsystem: failed to bind 2000000.aips-bus:ldb@020e0008 (ops imx_ldb_ops): -517
[ 5.748477] imx-drm display-subsystem: master bind failed: -517
Regards,
awesome - fyi - the u-boot is outputting correctly to the HDMI - so that is a good thing!
also, when you say added v4.9 - you mean the linux from armv7-multiplatform?
Correct, v4.9.x branch from armv7-multiplatform
PS, when you boot with the newer u-boot and v4.9.x make sure it’s passing root=PARTUUID=something-01 as this works around the mmc node number change in v4.5+…
Running uname_boot ...
Using: mmcroot=PARTUUID=0749dc41-01 ro ...
loading /boot/vmlinuz-4.9.7-armv7-x4 ...
6385856 bytes read in 388 ms (15.7 MiB/s)
loading /boot/dtbs/4.9.7-armv7-x4/imx6q-sabresd.dtb ...
51594 bytes read in 354 ms (141.6 KiB/s)
debug: [console=ttymxc0,115200 root=PARTUUID=0749dc41-01 ro rootfstype=ext4 rootwait] ...
debug: [bootz 0x12000000 - 0x18000000] ...
Kernel image @ 0x12000000 [ 0x000000 - 0x6170c0 ]
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800f989
Starting kernel ...
Regards,
I am not following you here (I’m pretty much a newbie with this build system).
normally I have something like: “mmcroot=/dev/mmcblk2p2 ro”
are you saying that it should be something like: “mmcroot=PARTUUID=123456cc-01 ro” ?
does it matter what the “something” is (in the above ‘123456cc’ ) ?
It’s your choice:
Anything before v4.5.x, you can use:
mmcroot=/dev/mmcblk0p1 ro
But on this platform after v4.5.3:
mmcroot=/dev/mmcblk2p1 ro
Here’s one of my previous write up’s on this issue: V4.5.x+ mmc re-numbering changes
By using mmcroot=PARTUUID=123456cc-01 ro (which u-boot detects the 123456cc-01 part) you don’t have to worry about random mmc node name changes…
Regards,
BTW, Just tested v4.10.x-rcX, hdmi is busted there. (Ethernet is actually busted on my board too…)
Regards,
I need to prove that I can run ubuntu on base sabresd board and get some type of video out to prove
it can be done -and that I can add packages to it. Is there some type of kludge to get this to work?
t
So the kludge is, to just add: cmdline=video=HDMI-A-1:1024x768@60e to /boot/uEnv.txt
root@arm:~# cat /boot/uEnv.txt
uname_r=4.10.0-rc6-armv7-x1
However even that’s not working for me.
According to parse-edid, my monitor is detected, so ^ kludge isn’t required, but the hdmi isn’t coming up…
root@arm:~# cat /sys/class/drm/card1-HDMI-A-1/edid | parse-edid
Checksum Correct
Section "Monitor"
Identifier "DELL 1707FP"
ModelName "DELL 1707FP"
VendorName "DEL"
# Monitor Manufactured week 48 of 2006
# EDID version 1.3
# Digital Display
DisplaySize 340 270
Gamma 2.20
Option "DPMS" "true"
Horizsync 30-81
VertRefresh 56-76
# Maximum pixel clock is 140MHz
#Not giving standard mode: 1152x864, 75Hz
#Not giving standard mode: 1280x1024, 60Hz
Modeline "Mode 0" +hsync +vsync
EndSection
Something regressed on this board. (also just tested mainline imxv6v7 & multiv7 defconfig’s)
Regards,
when you say ‘board’ your physical board or the BSP package?
Hi Tom,
By board i mean the physical board.
Just tested v3.19.x < thru > v3.15.x no hdmi video.
Regards,
I tested on my brand new board with your solution - and still no hdmi video?
This is a bummer!
Best Regards
Hi Robert
I re-ran my configuration Linux version 4.10.0-rc6-armv7-x1. It looks
like I had another issue that was causing no HDMI output.
I fixed that issue - and I now have output to HDMI…Yeah!
But, it is blank screen…
Looking at the console output, it seems to have an error here:
[ TIME ] Timed out waiting for device dev-mmcblk2p1\xc2\xa0.device.
[DEPEND] Dependency failed for / .
[DEPEND] Dependency failed for Local File Systems.
Any thoughts?
tom
