I am trying to write EEPROM through the call i2c_write in board_detect.c. Data are partially written. But it is shifted 2 bytes ( i.e. data are placed into address + 2 ) as shown :
another problem is that first 16 byte data is not written.
I didn’t call i2c_init, etc. Assumed that i2c is initialized. Do you have any suggestions that may have caused these problems?
At first, I check i2c_write (… alen, ), it was not used inside the function i2c_write itself, but I believe it is passed into I2C_ADAP->write().
The data shifted by 2 bytes, it is the data struct is null terminated for string. So added 2 bytes. Cannot directly passing eeprom data struct pointer for writing.
Tricky stuff.
