Identify HIROSE connector
This connector is (according to the logo on it) a HIROSE connector, it has 8 conductors at 0.5 mm pitch. Note the connector pinched between the jaws of calipers, with measurements in mm. The view not on the calipers is oblique, to help visualize the clamping mechanism. It’s from a Bosch coffeemaker.
The real question is whether this part is available through DigiKey.
@wdhall
I found the H125756CT-ND
Also the dimensions it has do line up with what you show in the above images.
Drawing
https://www.hirose.com/product/download/?distributor=digikey&type=2d&lang=en&num=FH52-8S-0.5SH
Checking the measurements you provided, you’ve got it.
Thanks a bunch, I was getting weary of plodding through the catalog!
Best regards,
W Dale Hall
