Hello jmzanzinger,
I possible match to your connector, is WM24007CT-ND, and the mating connector is WM9209CT-ND
This is only going off the visual look. This connector has a 0.020" (0.50mm) pitch, and the mating height is listed as 3mm.
You will have to check the datasheet to verify all the specifications, and determine if this will be compatible for your application.
