Identify Piher pot shaft length from product code
I am looking at the DigiKey product
PC16SH-07IP04-473A2020-TA
the code P04, for a plastic 4mm shaft, does not appear in the Piher datasheet
https://www.piher.net/pdf/20-PC16v03.pdf
What are the specifics for the P04 shaft?
Welcome to the Technical Forum. I will send this to the Product Specialist to see if I can get an updated data sheet. I will let you know when I receieve an answer.
Many thanks
Piher_Sensing_Systems_PC-16.pdf (1005.9 KB)
I apologize about the delay. Please see the updated data sheet.
