Inconsistency between product description and product attributs
I noticed an inconsistency between the product description and the product attributes (Power) for the RN73R series resistors from KOA Speer Electronics.
Example Reference: RN73R2BTTD1001B25
Product Description: RES 1K OHM 0.1% 1/4W 1206
Product Attribute (Power): 0.4W, 2/5W
Could you please clarify which specification is correct?
Thank you in advance for your assistance.
Best regards,
Orpheus
Welcome to the forum
On the data sheet for the RN73R2BTTD1001B25, you’ll see that both power specs appear but there is a footnote reference mark for the 0.4W spec.
The footnote reads:
† See the Performance Characteristics table below for use of the resistor in Power Mode
The Power Mode specs in the table are a little different than the Standard Mode specs.
Thank you for the clarification!
