Incorrect datasheet and parameter info for the component
------Question for NANOASMDCH020F-2 Please Put your question below------
is this the correct component or the correct datasheet info?
Welcome to the DigiKey TechForum. Thanks for bringing this to our attention. Here is the correct datasheet for the Littelfuse High Temperature Series . I have sent a request to have our website updated with the correct datasheet.
Thank you. Keep in mind that also the component info is incorrect and it will not be showed in a search when filtering for certain parameters.
Thanks MVO
I did submit the request to the have the operating temperature changed since this is the Littelfuse High Temp series and also recommended all parts from this series be reviewed and corrected.
