If you’re having trouble finding the specific data you need on our value add cable assemblies, such as the pre-crimped leads or rectangular assemblies, you can scroll down to the bottom of the product listing to find the parts list used in the assembly and click on them to find the product attributes and data sheets for each individual part.
For example, let’s look at the DF13 series pre-crimped leads. If we look at the data sheet for one of these, in this case H4BXT-10102-R8-ND, we see that it links to the Hirose data sheet for the connectors themselves, no info on the wires. Under “Documents and Media” further down the product page, the other datasheets also fail to give us wire details apart from length and wire gauge. But if we go all the way down until we find the “Assembly Component” table we see that this used 1852RD001-ND as the wire, and if we look at the datasheet for this part we sure enough find all of the relevant details.
